test release: parallel-netcdf 1.3.0pre1
Wei-keng Liao wkliao at ece.northwestern.edu
Mon Apr 23 14:48:49 CDT 2012
I cannot find blrts_xlf on Intrepid.
I can build the prerelease with both compilers wrapper for GNU and the IBM compilers.
Below is another configure command line I used that uses the IBM compilers.
configure --prefix=$HOME/PnetCDF \
          --host powerpc-bgp-linux \
          --build powerpc64-suse-linux \
          --enable-fortran \
          CC=mpixlc CXX=mpixlcxx \
          F77=mpixlf90 F90=mpixlf90 \
          MPICC=mpixlc MPICXX=mpixlcxx \
          MPIF77=mpixlf90 MPIF90=mpixlf90 \
The problem you are seeing looks like a Makefile's issue, rather than the compiler's.
Could you send me src/lib/Makefile generated after running configure?
Wei-keng
On Apr 23, 2012, at 2:21 PM, Jim Edwards wrote:
> Hi Wei-keng,
> Can you install this on intrepid?   I was just about to test there.
> On Mon, Apr 23, 2012 at 12:43 PM, Wei-keng Liao <wkliao at ece.northwestern.edu> wrote:
> Hi, Jim,
> I just built the prerelease 1.3.0pre1 on Intrepid, the BGP at Argonne, but
> could not reproduce the error you reported. The Makefile in
> src/lib for building ncvalid has the following lines related to ncvalid.
> LIBRARY         = libpnetcdf.a
> PROGRAM         = ncvalid
> $(PROGRAM):     $(PROG_OBJS) $(LIBRARY)
>        $(LINK.c) $(PROG_OBJS) $(LIBRARY)
> So, it should put the library file at the end of link command.
> Could you tell us the configure command line you used and also
> send us the src/lib/Makefile?
> Here is my configure command line:
> ./configure --host powerpc-bgp-linux --build powerpc64-suse-linux --with-mpi=/bgsys/drivers/ppcfloor/comm CFLAGS="-Wall -g -O0"
> Wei-keng
> On Apr 21, 2012, at 8:09 AM, Jim Edwards wrote:
> > Hi Rob,
> > In building the prerelease the program ncvalid trys to link without libraries - this fails on bgl.   I fixed it by adding $(LIBS) to the link line in the src/lib/Makefile.
> > Jim
> > On Fri, Mar 30, 2012 at 1:55 PM, Rob Latham <robl at mcs.anl.gov> wrote:
> > Hello to our pnetcdf community.
> > Did you realize our last release was in August.  Of 2010?  In some
> > ways that's great: Parallel-NetCDF churns along, hopefully delivering
> > good performance, and we've had no show-stopping bugs come up forcing
> > us to make a new release.
> > However, development does continue, and we're feeling pretty good
> > about the new features in SVN trunk lately, so let's have a
> > pre-release so we can get these new features out into applications'
> > hands.
> > Of particular note:
> > - A new "buffered put" api, an extension to the non-blocking
> >  interface.  See the release notes for more information.
> > - Various bug fixes and optimizations
> > - You used to need a custom pnetcdf.h header file from Unidata if you
> >  wanted to build NetCDF-4 with parallel-netcdf support.  Now you no
> >  longer need their header file.
> > For more information, including download or SVN links, please see the
> > release notes:
> > https://trac.mcs.anl.gov/projects/parallel-netcdf/wiki/ReleaseNotes-1.3.0
> > ==rob (on behalf of the entire pnetcdf team at ANL and NWU)
> > Rob Latham
> > Mathematics and Computer Science Division
> > Argonne National Lab, IL USA
> > Jim Edwards
> Jim Edwards
