mvapich, nonblocking build issue
Rob Latham robl at mcs.anl.gov
Wed Oct 12 10:37:43 CDT 2011
On Wed, Oct 12, 2011 at 10:27:56AM -0500, Rob Latham wrote:
> On Mon, Sep 12, 2011 at 02:12:47PM -0500, Rob Latham wrote:
> > On Mon, Sep 12, 2011 at 02:33:38PM -0400, Brent Woodruff wrote:
> > > Thanks. Building MVAPICH2 versions is not a problem and I already have this working. I will advise our users that parallel-netcdf is not currently MVAPICH-1 compatible.
> > Well, the fix is easy enough: that one spot is all that needed cleaned
> > up.
> If you are still interested in supporting mvapich users, this
> "obviously correct" fix actually results in a bunch of test failures.
> You should not apply svn revision 926 (r932 reverts it) and should
> instead apply svn revision r929 (which includes a change to
> configure.in so you will have to 'autoreconf').
Terribly sorry: I'm getting tripped up by all the MPI implementations
this morning.  I missed a spot, so you'll also need svn revision 933.
==rob
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
