mvapich, nonblocking build issue
Rob Latham robl at mcs.anl.gov
Wed Oct 12 10:27:56 CDT 2011
On Mon, Sep 12, 2011 at 02:12:47PM -0500, Rob Latham wrote:
> On Mon, Sep 12, 2011 at 02:33:38PM -0400, Brent Woodruff wrote:
> > Thanks. Building MVAPICH2 versions is not a problem and I already have this working. I will advise our users that parallel-netcdf is not currently MVAPICH-1 compatible.
> Well, the fix is easy enough: that one spot is all that needed cleaned
> up.
If you are still interested in supporting mvapich users, this
"obviously correct" fix actually results in a bunch of test failures.
You should not apply svn revision 926 (r932 reverts it) and should
instead apply svn revision r929 (which includes a change to
configure.in so you will have to 'autoreconf').
We've accumulated a good pile of patches recently.  Looks like it's
time to put out 1.2.1 soon.
==rob
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
