pnetCDF performance issues
Russ Rew russ at unidata.ucar.edu
Sun Mar 6 18:34:31 CST 2011
Hi Bill,
> We've been running various benchmarks, including IOR (I know - there
> are lots of problems with this benchmark) and found that pnetCDF tends
> to perform poorly on several of the systems we're using.  We tracked
> it down to the header  on the netCDF file - if this header is written
> and isn't a good size (like 4MB), performance can become very poor.
> This may be an artifact of the MPI-IO implementation (which includes
> ones that use ROMIO), but it impacts uses of pnetCDF.  Have you seen
> this problem?  What is the best way to fix this (e.g., can/should
> pnetCDF expect unaligned writes to be poor in MPI-IO, and work to
> force aligned writes?).  Note that HDF-5 appears to work around this
> problem; in any event, in our tests, we didn't see a serious
> performance impact.
A relatively straightforward fix for new files would be to force the
header to always be a good size, such as a multiple of 4MB.  When
writing a new file, all other variable offsets are computed relative to
where the first variable begins.
--Russ
