pnetCDF performance issues
William Gropp wgropp at illinois.edu
Sun Mar 6 15:12:48 CST 2011
We've been running various benchmarks, including IOR (I know - there
are lots of problems with this benchmark) and found that pnetCDF tends
to perform poorly on several of the systems we're using.  We tracked
it down to the header  on the netCDF file - if this header is written
and isn't a good size (like 4MB), performance can become very poor.
This may be an artifact of the MPI-IO implementation (which includes
ones that use ROMIO), but it impacts uses of pnetCDF.  Have you seen
this problem?  What is the best way to fix this (e.g., can/should
pnetCDF expect unaligned writes to be poor in MPI-IO, and work to
force aligned writes?).  Note that HDF-5 appears to work around this
problem; in any event, in our tests, we didn't see a serious
performance impact.
Bill
William Gropp
Deputy Director for Research
Institute for Advanced Computing Applications and Technologies
Paul and Cynthia Saylor Professor of Computer Science
University of Illinois Urbana-Champaign
