two questions about building parallel netcdf
Wei-keng Liao wkliao at ece.northwestern.edu
Tue Oct 5 18:43:19 CDT 2010
Hi, George
Please set environment variable LIBS, so the intel compilers can find the proper MPI library, i.e.
setenv LIBS "-lmpi"
Wei-keng
On Oct 5, 2010, at 5:39 PM, George B. Myers wrote:
> I am trying to build parallel netcdf for an SGI Altix ICE machine.  I want to build it against SGIs MPT 1.25 with the Intel Compiler, version 11.1.046.  Before executing configure I have set these environment variables:
> setenv CC icc
> setenv FC ifort
> setenv F77 ifort
> setenv MPIF77 ifort
> setenv MPICC icc
> setenv FFLAGS "-O -mp"
> setenv CFLAGS "-O -mp"
> And loaded "modules" that point to mpt and the intel compiler.  The configure command line is:
> ./configure --prefix=/nasa/parallel-netcdf/1.1.1/mpt.1.25 --enable-fortran --disable-mpi-io-test
> I have tried several other combination of parameters to turn off the MPI-IO tests but it always results in:
> configure: error: Cannot find MPI-IO library
> First question is how do I get it to accept the disable?  I am guessing I am missing something obvious, so hopefully, someone will see it.  Oh, also, It may just be that it cannot find MPI_File_sync.  So, maybe the problem is not that it is ignoring the disable, but, that the MPI-IO implementation is lacking something needed by parallel-netcdf.  Just wondering.
> checking for library containing MPI_File_sync... no
> Second question is, is there a way to get it to generate shared libraries?  I saw a response somewhere when I was googling for help someone who seemed to be related to the project say, "who would want to do that?"  But, the problem is, MPT only creates shared libraries.  So, we need shared libraries, if we want it to work with MPT.
> Any thoughts would be appreciated.
> George
