pnetcdf with WRF
Wei-keng Liao wkliao at ece.northwestern.edu
Tue Nov 23 21:48:29 CST 2010
Can you add one more environment variable? and re-configure and make again.
MPIF77=mpif90
Your mpif77 complains about the "use pnetcdf" statement.
> PGFTN-S-0034-Syntax error at or near end of line (test_get.F: 10)
Wei-keng
On Nov 23, 2010, at 5:02 PM, Lev Lafayette wrote:
>> Hi, Lev,
> Hi Wei-keng,
>> After running make, could you also run "make testing"?
>> That will test some Fortran programs.
>> (It may take a while depending on your file system speed.)
> Using the openmpi/pgi compilers, I have the following results (text file attached). There are errors with the ncmpi_open, ncmpi_create but these seem to be expected. However after this, there is a significant run of assignment operation and declaration issues which correlate with the issues I initially mentioned... Any further advice would be extremely welcome!
> All the best,
> Lev Lafayette, Systems Administrator, Victorian Partnership for Advanced Computing, lev at vpac.org
> "If you are sending a reply to a message or a posting be sure you summarize the original at the top of the message, or include just enough text of the original to give a context. This will make sure readers understand when they start to read your response."  RFC 1855
> 110 Victoria Street                                        phone:   03 9925 4909
> Carlton South, Victoria 3053,  Australia          mobile:  0432 255 208
> <make.testing>
