pnetcdf with WRF
Lev Lafayette lev at vpac.org
Tue Nov 23 17:02:34 CST 2010
> Hi, Lev,
Hi Wei-keng,
> After running make, could you also run "make testing"?
> That will test some Fortran programs.
> (It may take a while depending on your file system speed.)
Using the openmpi/pgi compilers, I have the following results (text file attached). There are errors with the ncmpi_open, ncmpi_create but these seem to be expected. However after this, there is a significant run of assignment operation and declaration issues which correlate with the issues I initially mentioned... Any further advice would be extremely welcome!
All the best,
Lev Lafayette, Systems Administrator, Victorian Partnership for Advanced Computing, lev at vpac.org
"If you are sending a reply to a message or a posting be sure you summarize the original at the top of the message, or include just enough text of the original to give a context. This will make sure readers understand when they start to read your response."  RFC 1855
110 Victoria Street                                        phone:   03 9925 4909
Carlton South, Victoria 3053,  Australia          mobile:  0432 255 208
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20101124/291fe977/attachment.bin>
