problem to install parallel netcdf
Wei-keng Liao wkliao at ece.northwestern.edu
Mon Jun 7 10:07:29 CDT 2010
Hi, Florent,
If you need no fortran, please try
configure --disable-fortran
Wei-keng
On Jun 7, 2010, at 7:16 AM, Florent Marceteau wrote:
> Hello,
> I am trying to install netcdf on my computer (Ubuntu 10.04 64 bit). And I have a problem when I do the ./configure
> The end of the error message is this one :
> checking if Fortran "doubleprecision" is C "double"... yes
> checking for Fortran-equivalent to netCDF "byte"... byte
> checking for Fortran-equivalent to netCDF "short"... integer*2
> checking for Fortran "integer*8"... no
> configure: error: F77 does not support "integer*8"
> I use openmpi and I work in C++ so I don't really need fortran. I tried to use autoconf, but the result was the same.
> Thank you for your attention,
> Florent Marceteau
