parallel-netcdf-1.1.1 released
Gerald Creager gerry.creager at tamu.edu
Thu Jan 28 15:02:42 CST 2010
Rob Latham wrote:
> On Thu, Jan 28, 2010 at 12:18:49PM -0600, Gerald Creager wrote:
>> Hmmm. Been trying here on Ranger.tacc.utexas.edu and I've not held
>> my mouth right.  Therefore, a question... do CC, CXX, FC, F90 need
>> to point to serial or parallel instances of the compiler?
> On Ranger, I think it might work out better if you let the configure
> script do most of the work.  do 'mpicc', 'mpif90', and 'mpicxx' live
> in the same directory?     the --with-mpi=/path/to/mpi_dir  option to
> configure should find everything you need.
> CC, CXX, FC, and F90 should be the parallel compilers, unless there is
> something quirky about your build environment.
Hi, Rob,
I can get past configure and the environment variables are what I
generally use for WRF, anyway, so they're a non-issue.
I'm getting a compile, but all I'm getting is libpnetcdf.a, and no
libpnetcdf.so. Is this expected behavior?
gc
Gerry Creager -- gerry.creager at tamu.edu
Texas Mesonet -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.862.3983
Office: 1700 Research Parkway Ste 160, TAMU, College Station, TX 77843
