parallel-netcdf-1.1.1 released
Rob Latham robl at mcs.anl.gov
Thu Jan 28 12:42:42 CST 2010
On Thu, Jan 28, 2010 at 12:18:49PM -0600, Gerald Creager wrote:
> Hmmm. Been trying here on Ranger.tacc.utexas.edu and I've not held
> my mouth right.  Therefore, a question... do CC, CXX, FC, F90 need
> to point to serial or parallel instances of the compiler?
On Ranger, I think it might work out better if you let the configure
script do most of the work.  do 'mpicc', 'mpif90', and 'mpicxx' live
in the same directory?     the --with-mpi=/path/to/mpi_dir  option to
configure should find everything you need.
CC, CXX, FC, and F90 should be the parallel compilers, unless there is
something quirky about your build environment.
==rob
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
