Serial build on MacOSX?
John Michalakes john at michalakes.us
Thu Jan 28 14:13:09 CST 2010
Is it possible to build parallel-netcdf in serial mode on a workstation,
in this case a dual-quad Intel Mac OS X 10.5.8 system with MPICH 1.0.8?
The configure script is failing here:
    checking size of MPI_Offset... ./configure line 11386: -c: command
    not found
Whole config.log attached.  I want to do some serial development on this
workstation first, then move over to the big cluster once I've got it
working with one task.
John
John Michalakes, Software Engineer        michalak at ucar.edu
NCAR, MMM Division                   voice: +1 303 497 8199
3450 Mitchell Lane                     fax: +1 303 497 8181
Boulder, Colorado 80301 U.S.A.        cell: +1 720 209 2320
         http://www.mmm.ucar.edu/individual/michalakes
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20100128/6e81b715/attachment-0001.htm>
Type: /
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20100128/6e81b715/attachment-0001.bin>
