parallel-netcdf-1.1.1 released
Don Morton Don.Morton at alaska.edu
Wed Jan 27 17:48:32 CST 2010
I should also point out that 1.0.3 compiled just fine on this same machine.
FYI, this is all I did to compile 1.0.3:
wget http://ftp.mcs.anl.gov/pub/parallel-netcdf/parallel-netcdf-1.0.3.tar.gz
Currently untarred in $HOME/parallel-netcdf-1.0.3/
export FC=ftn
export MPIF77=ftn
export CC=cc
export MPICC=cc
then
./configure --prefix=$HOME/usr/local/pnetcdf
make
make install
On Wed, Jan 27, 2010 at 11:46 PM, Don Morton <Don.Morton at alaska.edu> wrote:
> I'm thinking (but could be dead wrong) that this isn't the issue.  In fact,
> configure certainly finds plenty of MPI stuff to talk about (just an
> excerpt).  That missing "c" deal is something I know I've run into in the
> past year or two, and it's just some trivial little mistake, so I'm going to
> follow that track for a bit.  Sure wish my brain could recall the details of
> last time this happened.  For some reason I'm thinking it might have
> something to do with a "c" flag on the ARFLAGS macro - that's ringing a bell
> - but again, I could be way out in left field on this...
> checking MPI-IO support in MPI implementation... yes
> checking for sys/types.h... yes
> checking for sys/stat.h... yes
> checking for stdlib.h... yes
> checking for string.h... yes
> checking for memory.h... yes
> checking for strings.h... yes
> checking for inttypes.h... yes
> checking for stdint.h... yes
> checking for unistd.h... yes
> checking for stdlib.h... (cached) yes
> checking for sys/types.h... (cached) yes
> checking for strerror... yes
> checking for working alloca.h... yes
> checking for alloca... yes
> checking for struct stat.st_blksize... yes
> checking for IEEE floating point format... yes
> checking for size_t... yes
> checking if MPI_Offset is size 8... yes
> checking for MPI_Request_get_status... yes
> checking for MPI_Type_dup... yes
> checking for MPI_Info_dup... yes
> On Wed, Jan 27, 2010 at 11:41 PM, Rob Latham <robl at mcs.anl.gov> wrote:
>> On Wed, Jan 27, 2010 at 02:36:37PM -0900, Don Morton wrote:
>> > OK, thanks, I'll go back and scrutinize the configure output (like I
>> should
>> > have to begin with).  This is a Cray XT5, where one simply sets the
>> > environment variables to "ftn" and it magically finds MPI and such.  So,
>> > maybe something's getting lost...
>> OK, that's good information.  We don't have a "README.CRAY-XT", so
>> when we get you running with a configure that works 100%, we'll add
>> one.
>> The "README.CRAY-X1" recipe isn't too far off.  Be sure to set the
>> MPIF90 and MPICXX environment variables, though.  Not sure if you
>> still need the '-eh' flag.
>> ==rob
>> Rob Latham
>> Mathematics and Computer Science Division
>> Argonne National Lab, IL USA
> Arctic Region Supercomputing Center
> http://www.arsc.edu/~morton/ <http://www.arsc.edu/%7Emorton/>
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20100127/62fe3efc/attachment-0001.htm>
