parallel netcdf version info
William Gropp wgropp at illinois.edu
Mon Jan 4 15:30:06 CST 2010
I'm still working on building the Fortran 90 interface for pnetCDF,
which requires some extensions to the MPICH2 F90 buildiface script.
Bill
On Jan 4, 2010, at 11:47 AM, Jim Edwards wrote:
> On Mon, Jan 4, 2010 at 9:24 AM, Rob Latham <robl at mcs.anl.gov> wrote:
> > Also - to complete the F90 interface I need to modify the *.c
> files in the
> > src/libf directory.   These files have a header line that states:
> > This file is automatically generated by buildiface -infile=../lib/
> pnetcdf.h
> > > -deffile=defs
> > >  * DO NOT EDIT
> > but I cannot find the program buildiface in the repository?
> Yeah, buildiface is an MPICH2 wrapper generator.  I think it is
> shipped along with any released MPICH2 tarball.  There's a script in
> src/libf called "createffiles" which calls buildiface with the right
> arguments and tells you what environment variable to set so that it
> can find the MPICH2 directory.
> I had a look at the mpich2 source and see that there is a separate
> buildiface file for f90.   It seems that ideally pnetcdf should be
> using this to build it's f90 interface and I see that it has
> provision to generate the piece of the interface that I still
> haven't completed.   It would also complete the circle so you
> wouldn't need to remember to update the f90 interface if you make a
> change in the C API.   I think that this is the right way to do it
> but I'm not even sure where to begin to get this working - do you
> have some cycles to look into it Rob?
> ==rob
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
> You received this message because you are subscribed to the Google
> Groups "parallelio" group.
> To post to this group, send email to parallelio at googlegroups.com.
> To unsubscribe from this group, send email to parallelio+unsubscribe at googlegroups.com
> For more options, visit this group at http://groups.google.com/group/parallelio?hl=en
William Gropp
Deputy Director for Research
Institute for Advanced Computing Applications and Technologies
Paul and Cynthia Saylor Professor of Computer Science
University of Illinois Urbana-Champaign
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20100104/d3b23ac2/attachment.htm>
