which function calls nfmpi_put_vara_all()?
Shawn Kim shawn.subscribe at gmail.com
Mon Feb 15 16:13:10 CST 2010
Hi Kui
I got it. Thank you so much. :)
On Mon, Feb 15, 2010 at 12:17 AM, Kui Gao <kgao at eecs.northwestern.edu>wrote:
> Hi Shawn,
>       The back-trace is follows.
>        MPI_File_write_all() <--
> ncmpi_put_vara_all()<-ncmpi_put_vara_int_all()/ncmpi_put_vara_double_all().
> ncmpi_put_vara_int_all()/ncmpi_put_vara_double_all() are called in
> ncmpi_parallel_write.c and ncmpi_parallel_write_single.c.
>        Best regards,
> Kui.
> On Feb 14, 2010, at 9:15 PM, Shawn Kim wrote:
> > Hi,
> > I've run a Flash IO benchmark using parallel-netcdf-1.1.1. Currently I am
> trying to back-trace MPI_File_write_all() call, in such that
> MPI_File_write_all() <-- ncmpi_put_vara_all() <-- nfmpi_put_vara_all(), and
> so on. (parallel-netcdf-1.1.1/src/libf/put_vara_allf.c)
> > What I want to know is which function calls nfmpi_put_vara_all(). I
> grepped to find it in parallel-netcdf-1.1.1 as well as flash benchmark, but
> I couldn't do it.
> > Can you help me do it?
> > Thank you,
> > Shawn
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20100215/832a09a4/attachment.htm>
