which function calls nfmpi_put_vara_all()?
Kui Gao kgao at eecs.northwestern.edu
Sun Feb 14 23:17:29 CST 2010
Hi Shawn,
       The back-trace is follows.
	MPI_File_write_all() <-- ncmpi_put_vara_all()<-ncmpi_put_vara_int_all()/ncmpi_put_vara_double_all(). ncmpi_put_vara_int_all()/ncmpi_put_vara_double_all() are called in ncmpi_parallel_write.c and ncmpi_parallel_write_single.c.
	Best regards,
Kui.
On Feb 14, 2010, at 9:15 PM, Shawn Kim wrote:
> Hi,
> I've run a Flash IO benchmark using parallel-netcdf-1.1.1. Currently I am trying to back-trace MPI_File_write_all() call, in such that MPI_File_write_all() <-- ncmpi_put_vara_all() <-- nfmpi_put_vara_all(), and so on. (parallel-netcdf-1.1.1/src/libf/put_vara_allf.c)
> What I want to know is which function calls nfmpi_put_vara_all(). I grepped to find it in parallel-netcdf-1.1.1 as well as flash benchmark, but I couldn't do it.
> Can you help me do it?
> Thank you,
> Shawn
