paralell-netcdf-1.1.1 installation problem
Shawn Kim shawn.subscribe at gmail.com
Thu Feb 4 00:18:42 CST 2010
I finally succeeded to install pnetcdf-1.1.1 after changing
"--with-mpi=where/I/installed" and can run a FLASH IO benchmark.
I appreciate all your help.
- Shawn
On Wed, Feb 3, 2010 at 11:59 AM, Rob Latham <robl at mcs.anl.gov> wrote:
> On Wed, Feb 03, 2010 at 11:40:37AM -0500, Shawn Kim wrote:
> > Hi,
> > I did autoreconf before "configure". I attached the output from configure
> > and macros.make.
> > Thank you.
> > - Shawn
> > $ ./configure
> --prefix=/home/mdl/yuazhang/IOTracing/benchmark/parallel-netcdf-1.1.1/install
> > --with-mpi=/home/mdl/yuazhang/IOTracing/mpich2-1.0.8 --enable-fortran | &
> Is mpich2-1.0.8 the directory where you built mpich2, or is it the
> directory where you installed it?
> > checking mpi C compiler ... configure: WARNING: mpicc either does not
> exist
> > or is not executable: falling back to mpicc
> > using mpicc
> > checking mpi C++ compiler ... using
> > /home/mdl/yuazhang/IOTracing/mpich2-1.0.8/bin/mpicxx
> > checking mpi Fortran 77 compiler ... configure: WARNING: mpif77 either
> does
> > not exist or is not executable: falling back to mpif77
> > using mpif77
> > checking mpi Fortran 90 compiler ... configure: WARNING: mpif90 either
> does
> > using mpif77
> These lines all point to the former.
> ==rob
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20100204/cf1c80eb/attachment.htm>
