parallel netcdf version info
Jim Edwards edwards.jim at gmail.com
Wed Dec 30 18:48:12 CST 2009
Wei-keng,
I was looking at mpinetcdf.f90 - I now see that that was the wrong file (you
should delete it from your repository).   I'll have a look at pnetcdf.F90
next week and get back to you.    But I do use nfmpi_get_var_all and if the
interface doesn't contain it, it won't work for my app.    I do think that I
know how to add this though, I'll look into it and get back to you.
Happy New Year,
Jim
On Wed, Dec 30, 2009 at 4:41 PM, Wei-keng Liao
<wkliao at ece.northwestern.edu>wrote:
> In the Fortran interface I wrote, all pnetcdf APIs are indeed functions,
> not subroutines.
> Those APIs without a data type in their names are not supposed to be
> visible to users. Each pnetcdf API is designed for a specific data
> type, so it is easy to keep a file portable. I did not add
> nfmpi_get_var_all to the interface on purpose.
> Actually, pnetcdf does not have nfmpi_put_var_all, in which this API
> makes little sense (every process writes the entire variable).
> Wei-keng
> On Dec 30, 2009, at 4:24 PM, Jim Edwards wrote:
>  I gave it a try to write something into configure but then realized that I
>> would need to be able to link mpi in order to call the
>> ncmpi_inq_libvers function which is something that you cannot do from
>> configure on all platforms.     I added a call in my libraries init function
>> to that function so that I will get a runtime failure with a descent error
>> message if the version is too old.
>> As for the f90 interface - I'm afraid what you have there won't work.
>> All of the subroutines should be functions and you are
>> missing the interface I am using - the  nfmpi_get_var_all and
>> nfmpi_put_var_all types.    I'm not sure yet but I think that I have
>> something that will generate the f90 interfaces from a template file - let
>> me give it a little thought, I may be able to contribute something here.
>> On Wed, Dec 30, 2009 at 2:50 PM, Wei-keng Liao <
>> wkliao at ece.northwestern.edu> wrote:
>> Hi, Jim,
>> I just uploaded a few changes to pnetcdf SVN. The most notable is the
>> Fortran module that contains the declaration of all the APIs and their
>> arguments. They should be able to detected most of the argument type
>> mismatch.
>> This is my first attempt and may contain hidden problems.
>> Please give it a try and let me know.
>> As for your suggestion on the library version, I think it is
>> a good idea. But I am not familiar with configure utility.
>> I will leave it to Rob Latham.
>> Wei-keng
>> On Dec 30, 2009, at 9:32 AM, Jim Edwards wrote:
>> I'm working on porting pio from parallel-netcdf 1.0.2 to 1.1.0 -
>> the fortran API changed a length variable from type default integer to
>> type mpi_offset_kind.  This caused some errors
>> that were a bit difficult to track down.
>> So now my updated PIO won't work with an earlier version of pnetcdf and I
>> want to build this into
>> configure.ac   Does anyone on this list already have this test?   The
>> string provided by the  pnetcdf library
>> isn't very parser friendly and the string in the svn trunk version is the
>> same as the 1.1.0 release...
>> const char *
>> ncmpi_inq_libvers(void) {
>>  return "version = 1.1.0 of 02 November 2009";
>> Can I request a more parser friendly function and perhaps an svn generated
>> version number so that we can distinguish between the
>> release version and a repository check out?
>> Thanks,
>> Jim
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20091230/6c9b85e5/attachment.htm>
