parallel netcdf version info
Wei-keng Liao wkliao at ece.northwestern.edu
Wed Dec 30 17:41:59 CST 2009
In the Fortran interface I wrote, all pnetcdf APIs are indeed functions,
not subroutines.
Those APIs without a data type in their names are not supposed to be
visible to users. Each pnetcdf API is designed for a specific data
type, so it is easy to keep a file portable. I did not add
nfmpi_get_var_all to the interface on purpose.
Actually, pnetcdf does not have nfmpi_put_var_all, in which this API
makes little sense (every process writes the entire variable).
Wei-keng
On Dec 30, 2009, at 4:24 PM, Jim Edwards wrote:
> I gave it a try to write something into configure but then realized
> that I would need to be able to link mpi in order to call the
> ncmpi_inq_libvers function which is something that you cannot do
> from configure on all platforms.     I added a call in my libraries
> init function to that function so that I will get a runtime failure
> with a descent error message if the version is too old.
> As for the f90 interface - I'm afraid what you have there won't
> work.   All of the subroutines should be functions and you are
> missing the interface I am using - the  nfmpi_get_var_all and
> nfmpi_put_var_all types.    I'm not sure yet but I think that I have
> something that will generate the f90 interfaces from a template file
> - let me give it a little thought, I may be able to contribute
> something here.
> On Wed, Dec 30, 2009 at 2:50 PM, Wei-keng Liao <wkliao at ece.northwestern.edu
> > wrote:
> Hi, Jim,
> I just uploaded a few changes to pnetcdf SVN. The most notable is the
> Fortran module that contains the declaration of all the APIs and their
> arguments. They should be able to detected most of the argument type
> mismatch.
> This is my first attempt and may contain hidden problems.
> Please give it a try and let me know.
> As for your suggestion on the library version, I think it is
> a good idea. But I am not familiar with configure utility.
> I will leave it to Rob Latham.
> Wei-keng
> On Dec 30, 2009, at 9:32 AM, Jim Edwards wrote:
> I'm working on porting pio from parallel-netcdf 1.0.2 to 1.1.0 -
> the fortran API changed a length variable from type default integer
> to type mpi_offset_kind.  This caused some errors
> that were a bit difficult to track down.
> So now my updated PIO won't work with an earlier version of pnetcdf
> and I want to build this into
> configure.ac   Does anyone on this list already have this test?
> The string provided by the  pnetcdf library
> isn't very parser friendly and the string in the svn trunk version
> is the same as the 1.1.0 release...
> const char *
> ncmpi_inq_libvers(void) {
>  return "version = 1.1.0 of 02 November 2009";
> Can I request a more parser friendly function and perhaps an svn
> generated version number so that we can distinguish between the
> release version and a repository check out?
> Thanks,
> Jim
