error in configure
Jim Edwards edwards.jim at gmail.com
Mon Dec 28 18:59:23 CST 2009
That works - thanks.    Here is another one.  I'm gettiing an error
 Input/Output data amount mismatch
that I've traced to the mpinetcdf.c file at around line 2000  where I added
a couple of print statements
    printf("line %d nelems %d cnelems %d\n",__LINE__,nelems,cnelems);
  if (nelems != cnelems) {
    if (warning == NC_NOERR)
      warning = NC_EIOMISMATCH;
    (nelems>cnelems) ? (nelems=cnelems) : (cnelems=nelems);
This results in the output:
   1:line 2012 nelems 27 cnelems 27
   1:line 2016 nelems 27 cnelems 27
On Mon, Dec 28, 2009 at 5:38 PM, Wei-keng Liao
<wkliao at ece.northwestern.edu>wrote:
> Hi,
> If you run autoreconf first, it will generate that file for you.
> Wei-keng
> On Dec 28, 2009, at 2:47 PM, Jim Edwards wrote:
>  Hi,
>> Tried checking out the svn trunk and get the following configure error...
>> configure: error: cannot find sources (src/lib/ncconfig.in) in . or ..
>> what happened to this file?
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20091228/edc53497/attachment.htm>
