error in configure
Wei-keng Liao wkliao at ece.northwestern.edu
Mon Dec 28 18:38:54 CST 2009
If you run autoreconf first, it will generate that file for you.
Wei-keng
On Dec 28, 2009, at 2:47 PM, Jim Edwards wrote:
> Hi,
> Tried checking out the svn trunk and get the following configure
> error...
> configure: error: cannot find sources (src/lib/ncconfig.in) in . or ..
> what happened to this file?
