bugy 1.1.0
Kui Gao kgao at eecs.northwestern.edu
Sat Dec 5 12:09:13 CST 2009
Hi Lie-Quan,
         Please run "mpiexec -n 4 test_write test_double.nc". The test
assumes that the number is 4 in test/data/test_write.c.
         The ncdump of the resulting data file is as follows.
netcdf test_double {
// file format: CDF-1
dimensions:
        x = 100 ;
        y = 100 ;
        z = 100 ;
        time = UNLIMITED ; // (100 currently)
variables:
        double square(x, y) ;
                square:description = "2-D integer array" ;
        double cube(x, y, z) ;
        double time(time) ;
        double xytime(time, x, y) ;
// global attributes:
                :title = "example netCDF dataset" ;
data:
 square =
  0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20,
    21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38,
    39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56,
    57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74,
    75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92,
93, 94, 95, 96, 97, 98, 99,
Kui.
  _____
From:  [mailto:parallel-netcdf-bounces at lists.mcs.anl.gov] On Behalf Of
Lie-Quan Lee
Sent: Saturday, December 05, 2009 2:14 AM
To: parallel-netcdf at mcs.anl.gov
Subject: Re: bugy 1.1.0
Oops, I guess that I may not understand how to run test_double.
Anyhow, the redef problem is true. Attached is the testing program to show
the probelm. Please help. Thanks.
Best regards,
Lie-Quan
On Fri, Dec 4, 2009 at 10:30 PM, Lie-Quan Lee <liequan at gmail.com> wrote:
Dear Parallel-netcdf Developers,
I really would like to use version 1.1.0 for its CDF-5 format in our
simulation. However, there are some issues (unrelated to CDF-5) in the
release 1.1.0. For example, the test_write program under test/test_double
failed to generated the right data file (as in test/data/test_double.nc).
Here is the ncdump of the resuting data file:
netcdf t {
dimensions:
    x = 100 ;
    y = 100 ;
    z = 100 ;
variables:
    double time(time) ;
data:
 square =
  0, nan, 2, nan, 4, nan, 6, nan, 8, nan, 10, nan, 12, nan, 14, nan, 16,
nan,
    18, nan, 20, nan, 22, nan, 24, nan, 26, nan, 28, nan, 30, nan, 32, nan,
    34, nan, 36, nan, 38, nan, 40, nan, 42, nan, 44, nan, 46, nan, 48, nan,
    50, nan, 52, nan, 54, nan, 56, nan, 58, nan, 60, nan, 62, nan, 64, nan,
    66, nan, 68, nan, 70, nan, 72, nan, 74, nan, 76, nan, 78, nan, 80, nan,
    82, nan, 84, nan, 86, nan, 88, nan, 90, nan, 92, nan, 94, nan, 96, nan,
    98, nan,
  nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan,
nan,
  200, nan, 202, nan, 204, nan, 206, nan, 208, nan, 210, nan, 212, nan, 214,
The testing environment is:
OS: Linux x64 (RHEL4)
Compiler: gcc 4.2.2
MPI: mpich2 1.0.7
Also, in my application, open an existing netcdf and add a new variable
(2-d) messed up the existing data somehow.  The same code works when
parallel-netcdf release 1.0.3 or early is used.
Best regards,
Lie-Quan Lee
SLAC National Accelerator Laboratory
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20091205/95504f52/attachment.htm>
