bugy 1.1.0
Lie-Quan Lee liequan at gmail.com
Sat Dec 5 02:14:17 CST 2009
Oops, I guess that I may not understand how to run test_double.
Anyhow, the redef problem is true. Attached is the testing program to show
the probelm. Please help. Thanks.
Best regards,
Lie-Quan
On Fri, Dec 4, 2009 at 10:30 PM, Lie-Quan Lee <liequan at gmail.com> wrote:
> Dear Parallel-netcdf Developers,
> I really would like to use version 1.1.0 for its CDF-5 format in our
> simulation. However, there are some issues (unrelated to CDF-5) in the
> release 1.1.0. For example, the test_write program under test/test_double
> failed to generated the right data file (as in test/data/test_double.nc).
> Here is the ncdump of the resuting data file:
> netcdf t {
> dimensions:
>     x = 100 ;
>     y = 100 ;
>     z = 100 ;
>     time = UNLIMITED ; // (100 currently)
> variables:
>     double square(x, y) ;
>         square:description = "2-D integer array" ;
>     double cube(x, y, z) ;
>     double time(time) ;
>     double xytime(time, x, y) ;
> // global attributes:
>         :title = "example netCDF dataset" ;
> data:
>  square =
>   0, nan, 2, nan, 4, nan, 6, nan, 8, nan, 10, nan, 12, nan, 14, nan, 16,
> nan,
>     18, nan, 20, nan, 22, nan, 24, nan, 26, nan, 28, nan, 30, nan, 32, nan,
>     34, nan, 36, nan, 38, nan, 40, nan, 42, nan, 44, nan, 46, nan, 48, nan,
>     50, nan, 52, nan, 54, nan, 56, nan, 58, nan, 60, nan, 62, nan, 64, nan,
>     66, nan, 68, nan, 70, nan, 72, nan, 74, nan, 76, nan, 78, nan, 80, nan,
>     82, nan, 84, nan, 86, nan, 88, nan, 90, nan, 92, nan, 94, nan, 96, nan,
>     98, nan,
>   nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan,
> nan,
> nan,
>   200, nan, 202, nan, 204, nan, 206, nan, 208, nan, 210, nan, 212, nan,
> 214,
> The testing environment is:
> OS: Linux x64 (RHEL4)
> Compiler: gcc 4.2.2
> MPI: mpich2 1.0.7
> Also, in my application, open an existing netcdf and add a new variable
> (2-d) messed up the existing data somehow.  The same code works when
> parallel-netcdf release 1.0.3 or early is used.
> Best regards,
> Lie-Quan Lee
> SLAC National Accelerator Laboratory
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20091205/9f7fc798/attachment.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20091205/9f7fc798/attachment.obj>
