strerror
michael bane michael.bane at manchester.ac.uk
Wed Jun 20 09:39:00 CDT 2007
Sorry to show my naivety about [p-]netcdf, but am I correct in thinking
that the error codes for the f77 and f90 interfaces, ie as returned by
	nf_strerror(stat)
	nf90_strerror(stat)
are the same?
And that some of the p-netcdf error codes are the same? But that some
values of stat give "unknown error"?
So how would I go about determining what error code -26 (p-netcdf)
actually means? In context of the code segment:
! (v) use val(:) to fill varID
           write(*,*) 'p-netcdf: put var'
! NB: collective 'all vals of var' not exist
!!!        write(*,*) SHAPE(val)
!!!        write(*,*) start, count
!!!        write(*,*) start+count
           start=1
           count=max_c
!           stat = nfmpi_put_vara_double_all(ncfileID, varID, start,
count, val)
           stat = nfmpi_put_vara_double(ncfileID, varID, start, count,
val)
           if (stat /= nf_noerr) call print_nf90error_and_abort(stat)
           write(*,*) 'done'
I can't see what I've done wrong - this is running on 1 PE and the
"_all" (collective) call works fine if uncommented.
Many thanks,
Michael Bane
Centre for Atmospheric Science
University of Manchester, U.K.
http://cloudbase.phy.umist.ac.uk/people/bane/bane.htm
