pre-release: parallel-netcdf 1.0.2pre1 - configure on AIX
Jim Edwards jedwards at ucar.edu
Fri Feb 16 16:56:31 CST 2007
In several of the src/lib/*.c files there is
#ifdef HAVE_STDLIB_H
#include <stdlib.h>
#endif
HAVE_STDLIB_H is defined in ncconfig.h which is included by nc.h - one of
these two files needs to be included in each file prior to the above test -
otherwise stdlib.h is not included and malloc returns an int which will
cause a 64-bit compile to fail when allocating pointers.
On 2/16/07, Jim Edwards <jedwards at ucar.edu> wrote:
> I find that I am also having this issue on AIX - have you made any
> progress in finding the problem?  ( i've traced the coredump to an
> assignment in ncmpiio_new
>  nciop->ioflags = ioflags;
> it seems that the nciop memory is corrupt, but i haven't figured out why.
> Jim
> On 2/15/07, Patrick Jöckel <joeckel at mpch-mainz.mpg.de> wrote:
> > Hello Jim,
> > thank's for the fix. This worked fine for the configure.
> > Unfortunately the segmentation faults remain.
> > Yours,
> > Patrick
> > On Thursday 15 February 2007 15:29, Jim Edwards wrote:
> > > > configure shows the following problem:
> > > > checking for working alloca.h... yes
> > > > checking for alloca... yes
> > > > checking for struct stat.st_blksize.. . yes
> > > > checking for IEEE floating point format... yes
> > > > checking for size_t... yes
> > > > ./configure[5919]: test: argument expected
> > > > ./configure[5967]: test: argument expected
> > > > ./configure[6015]: test: argument expected
> > > > checking for MPI_Request_get_status... yes
> > > > checking for MPI_Type_dup... yes
> > > > checking if MPI includes MPI_COMBINER_DUP... yes
> > > > checking if MPI includes MPI_COMBINER_HVECTOR_INTEGER... yes
> > > Patrick,
> > > The three errors in configure are due to missing quotes on line 194 of
> > > configure.in.   I don't know if they have anything to do with your
> > other
> > > error...
> > > On 2/8/07, Jim Edwards <edwards.jim at gmail.com> wrote:
> > > > Rob,
> > > > I found the problem:
> > > > configure. in < http://configure.in> line 194 needs quotes:
> > > > if test ! "$ac_cv_sizeof_MPI_Offset"; then
> > > > On 2/8/07, Jim Edwards <edwards.jim at gmail.com > wrote:
> > > > > Tried that and got the same problem.  I'm sending the entire
> > > > > config.logbecause it looks like both tests are in there.
> > > > > On 2/8/07, Robert Latham < robl at mcs.anl.gov> wrote:
> > > > > > On Thu, Feb 08, 2007 at 02:52:37PM -0700, Jim Edwards wrote:
> > > > > > > Hi Rob,
> > > > > > > Did you forget to update configure from configure.in?  I see
> > that
> > > > > > Chris's
> > > > > > > change is there.   I also tried by hand his change and it will
> > work
> > > > > > fine.
> > > > > > There must be a bug in my "make the release" script. That's why
> > I
> > > > > > asked about your config.log -- to make sure it was testing what
> > I
> > > > > > thought it should be testing.
> > > > > > Can you confirm that if you re-run 'autoconf', you get a
> > configure
> > > > > > script that works for you on AIX?  Or is there still a problem
> > with
> > > > > > Fortran type detection?
> > > > > > Thanks
> > > > > > ==rob
> > > > > > Rob Latham
> > > > > > Mathematics and Computer Science Division    A215 0178 EA2D B059
> > 8CDF
> > > > > > Argonne National Lab, IL USA                 B29D F333 664A 4280
> > 315B
> > Dr. Patrick Joeckel
> > Max Planck Institute for Chemistry
> > Joh.-J. Becher Weg 27
> > 55128 Mainz                   phone:++49-6131-305452
> > Germany                       fax  :++49-6131-305436
> >                              e-mail:joeckel at mpch-mainz.mpg.de
> >                          http://www.mpch-mainz.mpg.de/~joeckel<http://www.mpch-mainz.mpg.de/%7Ejoeckel>
> > Nicht das Erreichte zaehlt, sondern das Erzaehlte reicht!
> >    (frei nach Ingo Borchers)
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20070216/1e639acf/attachment.htm>
