pre-release: parallel-netcdf 1.0.2pre1 - configure on AIX
Patrick Jöckel joeckel at mpch-mainz.mpg.de
Thu Feb 15 10:54:41 CST 2007
Hello Jim,
thank's for the fix. This worked fine for the configure.
Unfortunately the segmentation faults remain.
Yours,
 Patrick
On Thursday 15 February 2007 15:29, Jim Edwards wrote:
> > configure shows the following problem:
> > checking for working alloca.h... yes
> > checking for alloca... yes
> > checking for struct stat.st_blksize... yes
> > checking for IEEE floating point format... yes
> > checking for size_t... yes
> > ./configure[5919]: test: argument expected
> > ./configure[5967]: test: argument expected
> > ./configure[6015]: test: argument expected
> > checking for MPI_Request_get_status... yes
> > checking for MPI_Type_dup... yes
> > checking if MPI includes MPI_COMBINER_DUP... yes
> > checking if MPI includes MPI_COMBINER_HVECTOR_INTEGER... yes
> Patrick,
> The three errors in configure are due to missing quotes on line 194 of
> configure.in.   I don't know if they have anything to do with your other
> error...
> On 2/8/07, Jim Edwards <edwards.jim at gmail.com> wrote:
> > Rob,
> > I found the problem:
> > configure. in <http://configure.in> line 194 needs quotes:
> > if test ! "$ac_cv_sizeof_MPI_Offset"; then
> > > Tried that and got the same problem.  I'm sending the entire
> > > config.logbecause it looks like both tests are in there.
> > > On 2/8/07, Robert Latham < robl at mcs.anl.gov> wrote:
> > > > On Thu, Feb 08, 2007 at 02:52:37PM -0700, Jim Edwards wrote:
> > > > > Hi Rob,
> > > > > Did you forget to update configure from configure.in?  I see that
> > > > Chris's
> > > > > change is there.   I also tried by hand his change and it will work
> > > > fine.
> > > > There must be a bug in my "make the release" script. That's why I
> > > > asked about your config.log -- to make sure it was testing what I
> > > > thought it should be testing.
> > > > Can you confirm that if you re-run 'autoconf', you get a configure
> > > > script that works for you on AIX?  Or is there still a problem with
> > > > Fortran type detection?
> > > > Thanks
> > > > ==rob
> > > > Rob Latham
> > > > Mathematics and Computer Science Division    A215 0178 EA2D B059 8CDF
> > > > Argonne National Lab, IL USA                 B29D F333 664A 4280 315B
Dr. Patrick Joeckel
Max Planck Institute for Chemistry
Joh.-J. Becher Weg 27
55128 Mainz                   phone:++49-6131-305452
Germany                       fax  :++49-6131-305436
                             e-mail:joeckel at mpch-mainz.mpg.de
                         http://www.mpch-mainz.mpg.de/~joeckel
Nicht das Erreichte zaehlt, sondern das Erzaehlte reicht!
   (frei nach Ingo Borchers)
