pNetCDF hanging writing output from WRF
John Michalakes john at michalakes.us
Thu Oct 26 07:21:35 CDT 2006
All clear. Coding error on my part was causing the hangup. -John
> -----Original Message-----
> From: owner-parallel-netcdf at mcs.anl.gov
> [mailto:owner-parallel-netcdf at mcs.anl.gov]On Behalf Of John Michalakes
> Sent: Wednesday, October 25, 2006 12:47 PM
> To: parallel-netcdf at mcs.anl.gov
> Subject: pNetCDF hanging writing output from WRF
> Using a first-cut implementation of pNetCDF in WRF, I'm attempting to run
> and write history from 4 MPI processes on an IBM Power5+ system,
> using GPFS.
> The code is calling NFMPI_PUT_VARA_<type>_ALL routines for each output
> field, and it seems to work well until it gets to writing the 221st of 235
> fields at which point two processes (0 and 1) hang on a call to
> MPI_File_set_view down in set_vara_fileview (mpinetcdf.c).  The other two
> processes finish the sequence of writes to the WRF output file
> and go to the
> next phase of the computation.  The code will stay hung this way until
> killed.
> The fields being output are a mix of integer and real, and a mix of
> dimensions (3, 2, 1, and 0 dimensional).
> I've checked the sequence of calls to the pNetCDF layer and they match up
> field-for-field on all four processes and they all match up.
> Almost certainly this is a goof on my part, but any pointers where to look
> next will be much appreciated.
> Thanks,
> John
> John Michalakes, Software Engineer        michalak at ucar.edu
> NCAR, MMM Division                   voice: +1 303 497 8199
> 3450 Mitchell Lane                     fax: +1 303 497 8181
> Boulder, Colorado 80301 U.S.A.        cell: +1 720 209 2320
>         http://www.mmm.ucar.edu/individual/michalakes
