ERROR: 0032-184 on AIX5.3
Patrick Jöckel joeckel at mpch-mainz.mpg.de
Thu Oct 26 03:12:22 CDT 2006
Dear parallel-netcdf developers,
I successfully installed parallel-netcdf-1.0.1 on an IBM with AIX5.3.
However, when I run "ncmpidump" (or the tests like "poe ./nf_test -c" )
I always get (at the end) the message
      ERROR: 0032-184 MPI was not finalized  in routine unknown, task 0
The documentation says something like
"0032-184 MPI was not finalized in string, task number
Explanation: An MPI program exited without calling MPI_Finalize. The parallel
job is terminated with an error exit code.
User Response: Correct the program and/or determine if the program terminated
abnormally, perhaps via a library routine calling exit (0) after encountering
an error condition.
Error Class: MPI_ERR_OTHER
Is this problem (and the solution) known ?
Yours,
     Patrick
Dr. Patrick Joeckel
Max Planck Institute for Chemistry
Joh.-J. Becher Weg 27
55128 Mainz                   phone:++49-6131-305452
Germany                       fax  :++49-6131-305436
                             e-mail:joeckel at mpch-mainz.mpg.de
                         http://www.mpch-mainz.mpg.de/~joeckel
