Compilation problems on
Jim Edwards jedwards at ucar.edu
Wed Mar 29 07:47:54 CST 2006
Yu-Heng,
I am the installer of pnetcdf on frost - NCAR's BG/L.  Please send me the
complete output of your compile and I'll try to help you.
Jim Edwards
IBM Applications Analyst
NCAR
On 3/28/06, Yu-Heng Tseng <yhtseng at lbl.gov> wrote:
> Thanks for your quick response. Yes. The MPI is installed on NCAR's GB/L.
> The pnetcdf has been installed on /contrib/bgl/
> I also test one test example under test/fandc/pnf_test.F
> This program is working fine. That means parallel netcdf should work
> fine by calling
> the library. Any idea why it is not working well.
> Is that possible due to some 32 bits/64bits issues? Thanks!
> Yu-heng
> Reiner Vogelsang wrote:
> > Hi Yu-Heng Tseng,
> > do you have installed MPI?
> > If yes does your MPI installation support MPI-I/O?
> > Pnetcdf is using MPI-I/O to exploit parallelism.
> > Best wishes
> >     Reiner
> > Yu-Heng Tseng wrote:
> >> Hi,
> >> I tried to compile a code on BG/L with parallel netcdf. However, I
> >> got the following errors and many similar ones.
> >> /contrib/bgl/parallel-netcdf-1.0.0-pre2/lib/libpnetcdf.a(mpinetcdf.o):
> >> In function `check_mpifh':
> >> mpinetcdf.o(.text+0x460): undefined reference to `MPI_File_open'
> >> mpinetcdf.o(.text+0x474): undefined reference to `MPI_Error_string'
> >> In function `set_vars_fileview':
> >> mpinetcdf.o(.text+0x948): undefined reference to
> >> `MPI_Type_create_hvector'
> >> mpinetcdf.o(.text+0xacc): undefined reference to `MPI_File_set_view'
> >> mpinetcdf.o(.text+0xae0): undefined reference to `MPI_Error_string'
> >> In function `set_vara_fileview':
> >> Can anyone tell me how to fix this? It seems the simple test case
> >> working well when I include the library.
> >> Thank you very much.
> >> Yu-heng
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20060329/495a2286/attachment.html>
