parallel netcdf in a new NERSC Linux cluster
Rob Ross rross at mcs.anl.gov
Mon Oct 3 15:46:26 CDT 2005
that tests a necessary but not sufficient condition.  the functions also
need to be in the library...
rob
Wei-keng Liao wrote:
> Yu-Heng
> I think your mpicc version is not compiled with support of MPI-IO.
> You can test your mpicc to see if it supports MPI-IO by compiling the
> following short program.
> #include "mpi.h"
> int main() {
>    int a = MPI_MODE_RDWR;
>    return 0;
> Basically, you need a version of MPICH with MPI-IO enabled, before
> configuring pnetCDF.
> Wei-keng
> On Mon, 3 Oct 2005, Yu-Heng Tseng wrote:
>> Hi
>> I tried to install the parallel netcdf library on the new NERSC Linux
>> cluster. However, I got the following error. Any problem associated
>> with this?
>> checking mpi implementation... checking MPI-IO support in MPI
>> implementation... configure: error: mpi implementation does not
>> support MPI-IO
>> I include the following environment setting.
>> setenv MPICC mpicc
>> setenv MPIF77 mpif77
>> setenv F77 pathf90
>> setenv FC pathf90
>> setenv CC pathcc
>> setenv CXX pathCC
>> Thanks a lot for your help.
>> Yu-heng
