pnf_test.F
Robert Latham robl at mcs.anl.gov
Tue Sep 23 10:48:42 CDT 2003
On Tue, Sep 23, 2003 at 08:42:35AM -0700, John Tannahill wrote:
> Reiner,
> I believe pnf_test.F is one of the test codes I wrote.  My current version
> does not have the problem mentioned below, so you must be looking at an
> older one.  Did you get it from ANL's parallel netCDF library?  If so, what
> version of the library?  Can you send me a copy of what you have?  I have
> not used this particular test code in quite a while, but would be glad to
> update the archive with a new version if need be.
The pnf_test.F in parallel-netcdf-0.9.0 looks like the one Reiner is
using.  We'll gladly update pnf_test.F if you've made changes.
> As an aside, I am in the process of writing up my work on parallel netCDF
> and should finish it up by the end of the week.
I imagine that will be a very useful writeup.  Thanks for all your
help as an early user and for trying out our many iterations of the
Fortran bindings.
==rob
Rob Latham
Mathematics and Computer Science Division    A215 0178 EA2D B059 8CDF
Argonne National Labs, IL USA                B29D F333 664A 4280 315B
