0.9.0 installation
John Tannahill tannahill1 at llnl.gov
Mon Sep 8 11:41:20 CDT 2003
I have had pretty good success running a bunch of timings (different file
sizes, different numbers of processors) of 0.9.0 on NERSC's IBM SP.  I am
now trying to install 0.9.0 on a Compaq Teracluster 2000 that we have.  It
looks like I have installed older versions (not sure exactly what I had to
do?), but when I try to run the "make" on this version, I get the output
below.  Can anyone help me out?
Note that the ./configure --prefix=... seemed to work fine (did not run
autoconf); also did not use the --with-mpi=... argument.
John
/g/g17/jrt/pnetcdf/parallel-netcdf-0.9.0[29]: make
Making `all' in directory /g/g17/jrt/pnetcdf/parallel-netcdf-0.9.0/src
cd lib && make
gcc -c -O -I.   -DNDEBUG mpinetcdf.c
gcc -c -O -I.   -DNDEBUG header.c
gcc -c -O -I.   -DNDEBUG mpincio.c
gcc -c -O -I.   -DNDEBUG attr.c
gcc -c -O -I.   -DNDEBUG dim.c
gcc -c -O -I.   -DNDEBUG error.c
gcc -c -O -I.   -DNDEBUG nc.c
gcc -c -O -I.   -DNDEBUG ncx.c
gcc -c -O -I.   -DNDEBUG string.c
gcc -c -O -I.   -DNDEBUG var.c
ar cru libpnetcdf.a mpinetcdf.o  header.o  mpincio.o  attr.o  dim.o  error.o  nc
.o  ncx.o  string.o  var.o
ranlib libpnetcdf.a
m4 -B10000 -DAPI=C ./../../man/netcdf.m4 >pnetcdf.3  || rm pnetcdf.3
gcc -c -O -I.   -DNDEBUG validator.c
gcc -o ncvalid -O  validator.o  header.o  mpincio.o  attr.o  dim.o  nc.o  ncx.o
  string.o  var.o
MPI_Comm_rank
MPI_File_set_view
MPI_Error_string
MPI_File_read_at
MPI_Finalize
MPI_Bcast
MPI_File_delete
MPI_File_open
MPI_File_sync
MPI_Barrier
MPI_File_close
MPI_Comm_size
MPI_Allreduce
MPI_File_write_at
collect2: ld returned 1 exit status
*** Exit 1
Stop.
*** Exit 1
Stop.
*** Exit 1
Stop.
*** Exit 1
Stop.
       |                                          John R. Tannahill           |
       |    _/      _/      _/    _/  _/          Lawrence Livermore Nat. Lab |
       |   _/      _/      _/_/  _/  _/           P.O. Box 808, M/S L-103     |
       |  _/      _/      _/  _/_/  _/            Livermore, CA  94551        |
       | _/_/_/  _/_/_/  _/    _/  _/_/_/         Phone:  925-423-3514        |
       |                                          Fax:    925-423-4908        |
       | Lawrence Livermore National Laboratory   Email:  jrt at llnl.gov        |
