problems installing 0.9.0
John Tannahill tannahill1 at llnl.gov
Wed Sep 3 11:35:49 CDT 2003
Robert,
When I execute the following script to install 0.9.0 on NERSC's IBM-SP
(seaborg) =>
module load gnu
setenv CC     xlc
setenv FC     xlf
setenv MPICC  mpcc_r
setenv MPIF77 mpxlf_r
./configure --prefix=/usr/common/homes/j/jrt/tb2/parallel-netcdf-0.9.0 \
             --with-mpi=/usr/lpp/ppe.poe/bin
I get =>
loading cache ./config.cache
checking for top-level source-directory
/u2/jrt/tb2/parallel-netcdf-0.9.0
checking for a BSD compatible install... /usr/common/usg/gnu/bin/ginstall -c
checking for m4 preprocessor
checking for m4... m4
checking m4 flags... -B10000
checking for gcc... xlc
checking whether the C compiler (xlc -O ) works... yes
checking whether the C compiler (xlc -O ) is a cross-compiler... no
checking whether we are using GNU C... no
checking whether xlc accepts -g... yes
checking for c++... no
checking for g++... no
checking for gcc... no
checking for CC... no
checking for cxx... no
checking for cc++... no
checking for cl... no
checking whether the C++ compiler (gcc  ) works... no
configure: error: installation or configuration problem: C++ compiler cannot
create executables.
John
John R. Tannahill
Lawrence Livermore Nat. Lab.
P.O. Box 808, M/S L-103
Livermore, CA  94551
925-423-3514
Fax:  925-423-4908
