[Nek5000-users] interpolation of solution on extra points
Fri Sep 21 05:50:53 CDT 2018
Probably the easiest is to read in and directly write out with nek compiled with higher nx1.
Philipp
On September 21, 2018 11:53:48 AM GMT+02:00, nek5000-users at lists.mcs.anl.gov wrote:
>Hello all,
>Is it possible to write out the solution from Nek5000 with more points
>than
>actually used for calculation?
>Say, if I ran the simulation with poly. order 7 (i.e. 8 points inside
>each
>element per direction), can I write out the solution with 16 sampling
>points (i.e. solution interpolated on 16 points inside each element per
>direction)?
>Thanks for your time.
>BR
>Vishal
Sent from my Android device with K-9 Mail. Please excuse my brevity.
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180921/72100d61/attachment.html>
