[Nek5000-users] interpolation of solution on extra points
Fri Sep 21 04:53:48 CDT 2018
Hello all,
Is it possible to write out the solution from Nek5000 with more points than
actually used for calculation?
Say, if I ran the simulation with poly. order 7 (i.e. 8 points inside each
element per direction), can I write out the solution with 16 sampling
points (i.e. solution interpolated on 16 points inside each element per
direction)?
Thanks for your time.
BR
Vishal
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180921/8f4672f0/attachment.html>
