[Nek5000-users] 'COMMON' block issue
Mon Oct 8 22:37:09 CDT 2018
When you define your object in the common block, do you define it so that
it stays the same size regardless of how many threads you use?  Presumably,
it should look something like this:
common /mydata/ data(lx1*ly1*lz1*lelt)
So that when you double the number of threads, you halve the value of lelt
On Mon, Oct 8, 2018 at 8:25 PM <nek5000-users at lists.mcs.anl.gov> wrote:
> Dear Nek users,
> Currently, I am working on a simulation with a decent size (11760 * 12
> elements) employing ‘lpmin = 32’. When I compile, I received an error
> saying: “relocation overflows omitted from the output”.  I googled this
> error and it turned out this error comes from the ‘COMMON’ block;  Static
> data, such as COMMON variables, and all of the code together is still
> limited to 2GB under any mcmodel.  The suggested solution is to  move the
> data out of a COMMON block and into a module and make the data allocatable.
> The most straightforward way to avoid this would be increase the ‘lpmin’
> (for example if lpmin = 64, then it works), but this does not solve this
> issue, which is a big constraint. I am wondering has anyone has run into
> this and got any experience in solving it?
> Thanks a lot in advance
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20181009/05ed902e/attachment.html>
