[Nek5000-users] 'COMMON' block issue
Tue Oct 9 01:29:12 CDT 2018
you exceed 2 GB memory. Either compile with more processors or use
mcmodel=big flags (something like big-memory for Nek, I forgot).
On 2018-10-09 05:25, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Nek users,
> Currently, I am working on a simulation with a decent size (11760 * 12
> elements) employing ‘lpmin = 32’. When I compile, I received an error
> saying: “relocation overflows omitted from the output”.  I googled this
> error and it turned out this error comes from the ‘COMMON’ block; Static
> data, such as COMMON variables, and all of the code together is still
> limited to 2GB under any mcmodel.  The suggested solution is to  move
> the data out of a COMMON block and into a module and make the data
> allocatable.
> The most straightforward way to avoid this would be increase the ‘lpmin’
> (for example if lpmin = 64, then it works), but this does not solve this
> issue, which is a big constraint. I am wondering has anyone has run into
> this and got any experience in solving it?
> Thanks a lot in advance
> Nek5000-users mailing list
