[Nek5000-users] Boundary nodes cordinates and random generator
Tue Oct 16 13:31:31 CDT 2018
Yes I need some temporal correlation as well. In fact for me evaluating the complex exponential part is okay, the problem was computational expense for generating random number for 150 modes for theta,Phi,Psi and Alfa. I used the built in function of fortran and I experience Segmentation fault in my computer and when I use the code from Numerical recipes (subroutine ran1) it works well. But I just want to know why this happens and what are the other possible solutions.
By using the ran1 code from Numerical recipe, 150X4 = 600 random numbers are generated at each time step for the random Fourier mode velocities.
Or is there anyway solutions to cut down the number of random numbers by slightly any change in the Fourier mode?
And finally regarding the co ordinates of the inlet boundary is there any quick way to get it?
Regards
Sijo GEORGE
Your replay for my last question:
But I guess you want some temporal correlation as well, i.e. your modes
will evolve as a harmonic signal also in time? Typically, we chose a few
modes (say 150) with random wavenumbers and phases, but then we just
evolve them in space and time. So the problem is then rather to evaluate
the complex exponential (i.e. cosine and sine signals) than random numbers.
So in that case, one needs to have a RNG that works well in parallel and
you can restart a simulation without "kinks".
But if you do not need these properties, I would say that computing 150
random numbers is not very expensive. I typically use a quite "simple"
generator from Numerical recipes, just because it is portable and gives
the same numbers on all machines.
Philipp
