[Nek5000-users] Boundary nodes cordinates and random generator
Tue Oct 16 09:38:12 CDT 2018
Hi, how would your inflow turbulence model work? Do you need to create
150 random numbers every time step?
Philipp
On 2018-10-16 16:01, nek5000-users at lists.mcs.anl.gov wrote:
> Hello Neks,
> Its been a long time that I posted something in NEK5000. Here I came up
> with something which is simple.
> First thing is, I was trying to access the co ordinates of the inlet
> boundary elements for my free stream turbulence model(Von karman).
> I have an idea to get the using cbc(f,e,1) but I just would like to know
> is there any quick way to get the inlet bounday nodes coordinate.
> Second thing is about the making of random numbers.
> I know that in fortran there is an inbuilt function to generate random
> numbers (call random_generator(iseed)) but it seems it is an expensive
> process since my number of modes of turbulence model is 150.
> So just I have a question that how you usually generate random numbers
> when you model free stream turbulence?
> By the way I have completed the FSI calculation of NACA0012 at Re 64000
> in NEK5000. Thanks for your help.
> Regards
> Sijo GEORGE
> Nek5000-users mailing list
