[Nek5000-users] Genmap Error?
Wed Nov 7 14:09:07 CST 2018
What you see is not related to MAXNEL otherwise genmap would bail out with an error message.
On 7 Nov 2018, at 19:01, nek5000-users--- via Nek5000-users <nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> > wrote:
Hi!
Maybe you should increase MAXNEL parameter in maketools script (Nek5000/tools)?
nek5000-users <nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> >:
Hello,
I created a ".re2" mesh by converting an Exodus (".exo") mesh from Cubit
15.0 using the "exo2nek" script. It's a relatively large mesh (780k
elements) and I need to run it using parallel processing, and so I
wanted to use the "genmap" script.
However, I keep getting these errors, no matter what input mesh
tolerance value I use, from 0.2 to 0.00001):
genmap
Input .rea / .re2 name:
RCF_3D_FullSimple
  reading RCF_3D_FullSimple.re2
Input mesh tolerance (default 0.2):
NOTE: smaller is better, but generous is more forgiving for bad meshes.
0.00001
  reading mesh data ...
  start locglob_lexico: 8 775728 6205824
1.0000000000000001E-005
  locglob: 1 1 6205824
  locglob: 2 11290 6205824
  locglob: 3 15413 6205824
  locglob: 1 632909 6205824
  locglob: 2 632909 6205824
  locglob: 3 632909 6205824
593741 2 4 Matrix: SELF!!
        1 SELF!! 313837 313837 313837 313837
        2 SELF!! 313837 313837 313837 313837
  cont: SELF!! 593741
  ABORT: SELF-CHK 1 2 593741 0
  Try to tighten the mesh tolerance!
            0 quit
Do you have any idea what this means? Just from the output, it looks
like it's saying there are coincident vertices or elements? Is it a
problem with my mesh or with running the script?
Matt
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20181107/991db59c/attachment.html>
