[Nek5000-users] Conversion problem using exo2nek
Thu May 31 10:52:08 CDT 2018
Can you try again with the latest version available on GitHub. I know we fixed some importing issues from ICEM.
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Thursday 31st May 2018 17:48
> To: nek5000-users <nek5000-users at lists.mcs.anl.gov>
> Subject: Re: [Nek5000-users] Conversion problem using exo2nek
> yes you are right..it shows like this now :
> title         =  Created by ICEMCFD - EXODUS II Interface
> num_dim       =        3
> num_nodes     =     9261
> num_elem      =     1000
> num_elem_blk  =        1
> num_side_sets =        6
> element block id   =        1
> element type       =
> num_elem_in_block  =     1000
> num_nodes_per_elem =       27
> side set  0 num_sides =        0
> QA records =
> Converting elements ...
> done :: Converting elements
> Converting SideSets ...
> Sideset  0 ...
> done :: Sideset  0
> Sideset  0 ...
> done :: Sideset  0
> Sideset  0 ...
> done :: Sideset  0
> Sideset  0 ...
> done :: Sideset  0
> Sideset  0 ...
> done :: Sideset  0
> Sideset  0 ...
> done :: Sideset  0
> done :: Converting SideSets
> De: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
> À: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
> Envoyé: Jeudi 31 Mai 2018 17:43:07
> Objet: Re: [Nek5000-users] Conversion problem using exo2nek
> Details about the side sets included in the exodus file are printed during exo2nek execution.
> If none are reported, then the problem is most likely in the ICEM export step.
> <br class="" /><br class="" /><br class="" />On 31 May 2018, at 17:39, nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
> <br class="Apple-interchange-newline" />I checked the exo2nek.f file and I try to see the outputs to see wether is there any side sets. Then i encountered that there is no side sets. But i believe that I gave the side set numbers correctly on ICEM. <br class="" /><br class="" />Anyway I am gonna try again. So please dont care about the previous .re2 file. and sorry for lots of emails.<br class="" /><br class="" />Thank you<br class="" /><br class="" /><br class="" />-----------
> De: "nek5000-users" <nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov>><br class="" />À: "nek5000-users" <nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov>><br class="" />Envoyé: Jeudi 31 Mai 2018 17:25:47<br class="" />Objet: Re: [Nek5000-users] Conversion problem using exo2nek<br class="" /><br class="" />Can you post the exo2nek output?
> <br class="" />On 31 May 2018, at 17:21, nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
> <br class="Apple-interchange-newline" />Hi,<br class="" /><br class="" />I read the informations regarding the BC from exo2nek folder of NEK5000.<br class="" /><br class="" />There it says the 5th argument of fluid bc array.<br class="" /><br class="" />But when I acces it throught the user file everything is zero it seems.  (like this bc(5,j,i,1) )<br class="" /><br class="" />Could you please tell me if there is any problem with my conversion of exo2nek?<br class="" /><br class="" />Thank you<br class="" />Sijo<br class="" />_______________________________________________<br class="" />Nek5000-users mailing list<br class="" />Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov><br class="" />https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users><br class="" /><br class="" /><br class="" />_______________________________________________<br class="
 " />Nek5
 000-users mailing list<br class="" />Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov><br class="" />https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users<br class="" />_______________________________________________<br class="" />Nek5000-users mailing list<br class="" />Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov><br class="" />https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users<br class="" /><br class="" />
