[Nek5000-users] Conversion problem using exo2nek
Thu May 31 10:47:28 CDT 2018
yes you are right..it shows like this now :
title = Created by ICEMCFD - EXODUS II Interface
num_dim = 3
num_nodes = 9261
num_elem = 1000
num_elem_blk = 1
num_side_sets = 6
element block id = 1
element type =
num_elem_in_block = 1000
num_nodes_per_elem = 27
side set 0 num_sides = 0
QA records =
Converting elements ...
done :: Converting elements
Converting SideSets ...
Sideset 0 ...
done :: Sideset 0
Sideset 0 ...
done :: Sideset 0
Sideset 0 ...
done :: Sideset 0
Sideset 0 ...
done :: Sideset 0
Sideset 0 ...
done :: Sideset 0
Sideset 0 ...
done :: Sideset 0
done :: Converting SideSets
De: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
À: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
Envoyé: Jeudi 31 Mai 2018 17:43:07
Objet: Re: [Nek5000-users] Conversion problem using exo2nek
Details about the side sets included in the exodus file are printed during exo2nek execution.
If none are reported, then the problem is most likely in the ICEM export step.
On 31 May 2018, at 17:39, [ mailto:nek5000-users at lists.mcs.anl.gov | nek5000-users at lists.mcs.anl.gov ] wrote:
I checked the exo2nek.f file and I try to see the outputs to see wether is there any side sets. Then i encountered that there is no side sets. But i believe that I gave the side set numbers correctly on ICEM.
Anyway I am gonna try again. So please dont care about the previous .re2 file. and sorry for lots of emails.
Thank you
De: "nek5000-users" < [ mailto:nek5000-users at lists.mcs.anl.gov | nek5000-users at lists.mcs.anl.gov ] >
À: "nek5000-users" < [ mailto:nek5000-users at lists.mcs.anl.gov | nek5000-users at lists.mcs.anl.gov ] >
Envoyé: Jeudi 31 Mai 2018 17:25:47
Can you post the exo2nek output?
BQ_BEGIN
On 31 May 2018, at 17:21, [ mailto:nek5000-users at lists.mcs.anl.gov | nek5000-users at lists.mcs.anl.gov ] wrote:
I read the informations regarding the BC from exo2nek folder of NEK5000.
There it says the 5th argument of fluid bc array.
But when I acces it throught the user file everything is zero it seems. (like this bc(5,j,i,1) )
Could you please tell me if there is any problem with my conversion of exo2nek?
Thank you
Sijo
Nek5000-users mailing list
[ mailto:Nek5000-users at lists.mcs.anl.gov | Nek5000-users at lists.mcs.anl.gov ]
[ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ]
BQ_END
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180531/5d2b9f55/attachment-0001.html>
