[Nek5000-users] Integral on the wall
Sat May 12 05:56:45 CDT 2018
Dear Valerio,
Just modify the routine I sent to compute the average, but now weight the average by unx to get the x-component.
Do the same with uny for y, and unz for z.
Best,
Paul
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Saturday, May 12, 2018 5:44:50 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Integral on the wall
Dear Paul,
using the subroutine in zfunc.f I got the value of the pressure averaged on the surface. However I would like to compute the force on the wall as the line integral of the pressure times the normal (maybe my first question was unclear). Do you think this can be achieved modifying a bit the subroutine in zfunc.f or should I do it from scratch?
Thanks. Best,
Valerio
Da: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> per conto di nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Inviato: mercoledì 9 maggio 2018 15:11
A: nek5000-users at lists.mcs.anl.gov
Oggetto: Re: [Nek5000-users] Integral on the wall
Dear Paul,
Thank you for the help, I will test the routine zfunc.
Best,
Valerio
Inviato: mercoledì 9 maggio 2018 15:05
Dear Valerio,
I've not tested or even compiled the attached code...
But it should be fairly close to being functional.
The idea would be to pass in the pressure on mesh 1, which
means you need to interpolate from pr to pm1 ---- there are
several routines floating around to do this.
Please let me know if you have any questions and if you
are able to make this routine work.
Best,
Paul
PS - note that you should be able to send in "zm1" to this
routine and get back the correct z distribution.  This is what
I would do if I wished to plot pr vs z.   Also, you might want
to dsavg() pm1 if you want a continuous pressure estimate.
Sent: Wednesday, May 9, 2018 5:55:29 AM
Dear Valerio,
You would need to modify torque calc to do this,
assuming that your objective is to compute a line
integral of the pressure on the GLL points.
Assuming that your pipe mesh was made by
sweeping the geometry in the z direction with
n2to3, the modification should be quite easy.
The routine I would start with would be drgtrq
in navier5.f, which I see uses the two-index
loop to traverse faces based on jskip1 and jskip2.
For your case, I would use the facind() 3 index
loop approach (e.g., as used in norcmp2 routine).
Then you track the outer "k" loop and accumulate one
value for each k value and for each z level of the elements.
You will know the z level because it will be:
   klevel_e = 1 + (eg-1)/nelxy
where nelxy is the number of elements in your pipe
cross section.
Hopefully this will get you pointed in the right direction...
Best,
Paul
Sent: Wednesday, May 9, 2018 3:13:19 AM
Subject: [Nek5000-users] Integral on the wall
Dear all,
I want to compute the integral of the pressure on pipe wall at different cross-sections. I tried using the routine set_obj, setting as many objects as the number of elements along the pipe length and then using the routine torque_calc. However I would like to compute it on each circumference where GLL nodes are defined, for example if I use lx1 = 8 I would like to compute it on 8 cross-sections per element. Is there an efficient way to do this using the set_obj routine?
Thanks. Best regards.
Valerio
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180512/8018f1f8/attachment-0001.html>
