[Nek5000-users] Separate temperature perturbation field
Wed May 9 15:15:11 CDT 2018
Hello,
I'm working with teh effects of a local temperature perturbation in a
natural convection problem. To define the perturbations I intend to create
a separate field that will be added to the regular temperature field when
calculating the buoyancy force (ffz=Pr*(temp+temp_perturb)), but I'm having
troubles initializating and setting the values.
To build the field I added a common block in usric(), usrchk() and usrf()
    common /perturb/ temp_perturb(lx1,ly1,lz1,lelt,ldimt)
To initialize I tried to use rzero() as is used in avg_all():
      subroutine useric(ix,iy,iz,eg)
      integer ix,iy,iz,eg,eltot
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      ux   = 0.0
      uy   = 0.0
      uz   = 0.0
      t    = 0.0
      eltot = lx1*ly1*lz1*nelt
      do i = 1,ldimt
          call rzero(temp_perturb(1,1,1,1,i),eltot)
      enddo
      return
      end
To generate the files, in usrchk()
      subroutine userchk()
      include 'SIZE'
      include 'TOTAL'
      integer e,eg
      call outpost(vx,vy,vz,pr,temp_perturb,'pt1')
      call outpost2(vx,vy,vz,pr,temp_perturb,ldimt,'pt2')
      return
      end
But after running the simulation the temperature perturbation field is a
mess of NaNs and numbers of order 1e+38. Also, there's no other operation
with 'temp_perturb' in the .usr file.
Thanks in advance,
*Nicolás Andrés Órdenes Leiva*
Estudiante de Ingeniería Civil Mecánica
Universidad Técnica Federico Santa María
Tel: +56 9 7619 2857
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180509/45a4a10d/attachment.html>
