[Nek5000-users] Compiling Problems in "Running your very first simulation"
Tue May 8 06:31:30 CDT 2018
Yes, you can ignore the compiler warnings!
In case you want to double-check your local installation run the short tests. For more information please consult Nek5000/short_tests/README.md
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Tuesday 8th May 2018 13:17
> To: nek5000-users at lists.mcs.anl.gov
> Subject: [Nek5000-users] Compiling Problems in "Running your very first simulation"
> Hello,
> The title of my thread is the same as for an already existing thread (26-Sept-2017) because:
> I receive very similar warning messages when compiling nek5000 (./maketools all). Lots of warnings!
> From your answer on that thread it seems that you do not worry at all for the warning messages. Should we really not care about them? How to know which warnings are not of concern and which other are? Can you post your own .log file to see which warning messages are considered normal for you? Or how do you check everything went fine for the compilation?
> Anyway, I will start running the examples in order to learn about the usage of the code. And I guess any abnormality would appear there.
> Many thanks,
> Alexis
> Dr Alexis Espinosa
> Supercomputing Specialist
> Pawsey Supercomputing Centre
> 26 Dick Perry Ave
> Kensington  WA  6151
> Australia
> Tel  +61 xxxx xxxx
> Email  alexis.espinosa at pawsey.org.au <mailto:alexis.espinosa at pawsey.org.au>Web  www.pawsey.org.au <http://www.pawsey.org.au/>_______________________________________________
> Nek5000-users mailing list
