[Nek5000-users] Postprocessing: Append data to output file
Fri May 4 04:30:41 CDT 2018
Assuming you are using par, define a scalar:
[SCALAR01] # vorticity
solver = none
Then, just store the vorticity in t(1,1,1,1,iscal +1) where iscal is your passive scalar index (in this example 1).
On 4 May 2018, at 08:39, "nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> " <nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> > wrote:
I am postprocessing output files in order to compute the vorticity.
So far I have followed the instructions in https://lists.mcs.anl.gov/pipermail/nek5000-users/2010-March/000171.html,
where it is explained how to output the vorticity components as velocity components.
I however would like to make a simultaneous visualization of the vorticity field, the velocity field and some of the scalar fields.
If postprocessing a file "mycase0.f000XX" - is it then possible to append the vorticity to this file?
If this is not possible, how would I to in order to write the velocity and the vorticity in the same file?
The interface of the subroutine outpost is outpost(vx,vy,vz,pr,t,nam), but I have 3 scalars in addition to the temperature.
How can I write a file containing both the vorticity and the four scalar fields?
Best,
Johan
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180504/e0c1a83b/attachment.html>
