[Nek5000-users] ffx ffy ffz from current run
Thu May 3 18:03:18 CDT 2018
Dear Zhai,
Assuming you have a periodic domain in direction "d" (d=1,2,3 or x,y,z), and
that you have ffx=ffy=ffz=0 in your .usr file, then
grep volf logfile
will show a list of time step, time, and "ffd" + other columns.
Column 3 will be "ffd"
where ffd is the force in the direction "d" and d = |p54|.
p54 = +/-  1  ==>   d=x direction
           +/-  2 ==>         y direction
           +/-  3 ==>         z direction
If p54 < 0, then p55 determines the mean velocity in direction d
If p54 > 0, then p55 determines the volumetric flux in direction d
(Note that p55 < 0 would be the flow is in the reverse direction.)
hth,
Paul
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Thursday, May 3, 2018 11:47:44 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] ffx ffy ffz from current run
Hi Nek users,
How can I get the ffx ffy and ffz from the simulation with flowrate fixed, where ffx ffy and ffz are in usr file?
Kind regards,
Zhai
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180503/ecd674f3/attachment.html>
