[Nek5000-users] ffx ffy ffz from current run
Thu May 3 12:36:06 CDT 2018
Hi Jian,
Not exactly sure what you mean, but if you are using p54, p55 to set your flowrate, then you can use your logfile to get what the corresponding forcing should be using ffx/ffy/ffz.
As per drive2.f, if you are using param(54),param(55), then in logfile you can grep for “volflow”, and “scale” represents the ffx/ffy/ffz.
      if (nio.eq.0) write(6,1) istep,chv(icvflow)
     $   ,scale,delta_flow,current_flow,flow_rate
    1    format(i11,'  volflow ',a1,11x,1p4e13.4)
c     Note, this scale factor corresponds to FFX, provided FFX has
c     not also been specified in userf.   If ffx is also specified
c     in userf then the true FFX is given by ffx_userf + scale.
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180503/19d76cf4/attachment.html>
