[Nek5000-users] Output files reading by python
Fri Mar 16 03:47:46 CDT 2018
Hi Sijo, what format are you trying to read?
The files created by Nicolo (using python) are ONLY for *0.f0* files.
Best regards,
AW
Le 15/03/2018 à 23:50, nek5000-users at lists.mcs.anl.gov a écrit :
> Yes in fact I was using these codes. It was working for me with some cases and not with the file which I had attached. The header itself looks bit different. Could you please have look into that ?
> Thank you
> ----- Mail original -----
> De: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
> À: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
> Envoyé: Jeudi 15 Mars 2018 23:43:46
> Objet: Re: [Nek5000-users] Output files reading by python
> Hi,
> you can check the python library by Jacopo and Nicolo:
> https://github.com/jcanton/pymech
> There are also matlab routines around. Perhpas Adam can send you a link
> to these.
> Philipp
> On 2018-03-15 23:42, nek5000-users at lists.mcs.anl.gov wrote:
>> HI Neks,
>> I was trying to read the output files of NEK5000 using some python files
>> which are available in internet. But when I tried an old which is
>> attached in this email, it throws some error. But the same code was
>> working for other files. The attached file looks also bit different from
>> other files. I assume that the standard of construction for this file is
>> quite different from others. Could you please help me, to find a way to
>> read the NEK5000 output files by using python scripts? Or anyway to make
>> the standard output files?
>> Thanks
>> Sijo
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
*Arnold Wakim*
Ph.D. Student
Département Aérodynamique, Aéroélasticité, Acoustique
INST
Tél: +33 1 46 23 51 83
ONERA - The French Aerospace Lab - Centre de Meudon
8, rue des Vertugadins - 92190 MEUDON
Nous suivre sur : www.onera.fr <http://www.onera.fr> | Twitter
<http://www.twitter.com/@onera_fr> | LinkedIn
<http://www.linkedin.com/company/onera> | Facebook
<http://www.facebook.fr/thefrenchaerospacelab>
Avertissement/disclaimer http://www.onera.fr/onera-en/emails-terms
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180316/f3559569/attachment.html>
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180316/f3559569/attachment.gif>
