[Nek5000-users] Output files reading by python
Thu Mar 15 17:50:24 CDT 2018
Yes in fact I was using these codes. It was working for me with some cases and not with the file which I had attached. The header itself looks bit different. Could you please have look into that ?
Thank you
----- Mail original -----
De: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
À: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
Envoyé: Jeudi 15 Mars 2018 23:43:46
Objet: Re: [Nek5000-users] Output files reading by python
you can check the python library by Jacopo and Nicolo:
https://github.com/jcanton/pymech
There are also matlab routines around. Perhpas Adam can send you a link
to these.
Philipp
On 2018-03-15 23:42, nek5000-users at lists.mcs.anl.gov wrote:
> HI Neks,
> I was trying to read the output files of NEK5000 using some python files
> which are available in internet. But when I tried an old which is
> attached in this email, it throws some error. But the same code was
> working for other files. The attached file looks also bit different from
> other files. I assume that the standard of construction for this file is
> quite different from others. Could you please help me, to find a way to
> read the NEK5000 output files by using python scripts? Or anyway to make
> the standard output files?
> Thanks
> Sijo
> Nek5000-users mailing list
